I recently updated my checkout of the kicad-symbols repo, and got these warnings from git:
warning: CRLF will be replaced by LF in Amplifier_Audio.lib.
The file will have its original line endings in your working directory.
warning: CRLF will be replaced by LF in Amplifier_Buffer.dcm.
warning: CRLF will be replaced by LF in Amplifier_Buffer.lib.
warning: CRLF will be replaced by LF in Amplifier_Current.lib.
warning: CRLF will be replaced by LF in Amplifier_Difference.dcm.
warning: CRLF will be replaced by LF in Amplifier_Difference.lib.
warning: CRLF will be replaced by LF in Amplifier_Instrumentation.dcm.
warning: CRLF will be replaced by LF in Amplifier_Instrumentation.lib.
warning: CRLF will be replaced by LF in Amplifier_Operational.dcm.
warning: CRLF will be replaced by LF in Amplifier_Operational.lib.
warning: CRLF will be replaced by LF in Amplifier_Video.lib.
warning: CRLF will be replaced by LF in Comparator.lib.
warning: CRLF will be replaced by LF in MCU_Texas_MSP430.lib.
and then, although I haven’t made any changes in my local checkout, those files immediately show up as modified:
On branch master
Your branch is up-to-date with 'origin/master'.
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git checkout -- <file>..." to discard changes in working directory)
modified: Amplifier_Audio.lib
modified: Amplifier_Buffer.dcm
modified: Amplifier_Buffer.lib
modified: Amplifier_Current.lib
modified: Amplifier_Difference.dcm
modified: Amplifier_Difference.lib
modified: Amplifier_Instrumentation.dcm
modified: Amplifier_Instrumentation.lib
modified: Amplifier_Operational.dcm
modified: Amplifier_Operational.lib
modified: Amplifier_Video.lib
modified: Comparator.lib
modified: MCU_Texas_MSP430.lib
no changes added to commit (use "git add" and/or "git commit -a")
and there doesn’t seem to be any way to get rid of the modifications (I can do git reset --hard, which should get rid of all modifications, but the files still show up as modified).
Is there some reason this seems to only be causing a problem for me, and not for everyone else who uses this repo? How should I deal with it?
Thanks!
