Je voudrais obtenir un typon en négatif avec pcbnew, j’ai essayé avec le format svg mais il ne respecte pas la taille du pcb et donc inutilisable. Quelqu’un peut-il m’aider. Merci d’avance.
I would like to get a typon in negative with pcbnew, I tried with the svg format but it does not respect the size of the pcb and therefore unusable. Can anyone help me. Thanks in advance
Ne pas obtenir d’amour du moteur de recherche sur ce qu’est typon.
Not getting any love from the search engine on what typon is.
@hermit Typon means artwork in french. Leaning towards print templates for silkscreen or books atl.
Basically he means inverted graphics IMHO.
@hermit Out of curiosity: what’s the forum’s policy towards non english contributions? Help them as best we can?
Yes. I added the translations to that end. English isn’t the native tongue for many forum members anyhow.
An artwork is the circuit board drawing. Thank’s
Under the ‘plot’ menu there are choices for negative plot. You might check to see if those are what you need.
Indeed, there is the possibility to output a negative in SVG format but the dimensions of the PCB are not respected and therefore not usable. But I found a solution by using a Gerber editor. It’s a bit laborious but I have a correct negative. Thanks for helping me. Sincerely Dany
There’s a simple way to do this.
Install a virtual printer that can “print” to a bitmap file. For example PDFCreator. Save to TIFF, high resolution, or BMP. Black and white. Copper only, no silk, fab, etc.
Open the bitmap with a image editor that offers some effects. Apply “negative”.
Done.
Il y a une façon simple de le faire.
Installe une imprimante virtuelle qui peut
“imprimer” un bitmap. Par exemple PDFCreator.
Enregistre comme TIFF haute résolution, ou BMP, en N&B.
Ouvre le bitmap dans un logiciel de retouche d’image qui offre quelques effets. Applique l’effet “négatif”.
Ensuite fais un crop.
Fin de l’histoire.
(c’est comme ça que je fais mes fichiers “typons” pour laser transfer, mais bien sûr sans inverser !)
