Creepage DRC does not work
I have problems with the new creepage feature. This layout creates a DRC error, which correct:
Now I move the trace just a bit unter the slot. This layout creates no DRC error.
Am I doing something wrong?
My custom rules are:
(rule mains
   (constraint clearance (min 4mm))
   (condition "A.hasNetclass('Mains_Line') && B.hasNetclass('Mains_Neutral')"))
(rule mains2
   (constraint creepage (min 6mm))
Minimum example:
creepage-test.zip (8.7 KB)
Version:
Version: 9.0.0-9.0.0-2~ubuntu24.10.1, release build
wxWidgets 3.2.5
FreeType 2.13.3
HarfBuzz 9.0.0
FontConfig 2.15.0
libcurl/8.9.1 OpenSSL/3.3.1 zlib/1.3.1 brotli/1.1.0 zstd/1.5.6 libidn2/2.3.7 libpsl/0.21.2 libssh2/1.11.0 nghttp2/1.62.1 librtmp/2.3 OpenLDAP/2.6.8
Platform: Ubuntu 24.10, 64 bit, Little endian, wxGTK, X11, ubuntu-xorg, x11
Date: Feb 20 2025 21:17:37
wxWidgets: 3.2.5 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.83.0
OCC: 7.8.1
Curl: 8.9.1
ngspice: 43
Compiler: GCC 14.2.0 with C++ ABI 1019
KICAD_IPC_API=ON
Locale:
Lang: en_GB
Enc: UTF-8
Num: 1,234.5
Encoded кΊ丈: D0BACEA9E4B888 (sys), D0BACEA9E4B888 (utf8)
Please use “Preformatted text” for rules, I changed it for you as a model.
It is correct.
There is a nice feature for v9 Post-V8 New Features and Development News - #62 by Drinausaur
It showns this a bit clearer. It’s basically creepage (surface around slots) and clearance (through air)
In your 2nd shot the track has been moved so there isnt a straight line path to the other track and thus the creepage distance has (hopefully) been increased enough to pass your 6mm constraints
Unfortunately not, the creepage distance is significantly shorter than 6 mm. Even if I set the design rule to 10 mm, the DRC reports nothing.
Try one of the RCs for 9.0.1. There were several creepage bugs fixed, including one where creepage results disappear on subsequent runs.
I have repeated the test with version 9.0.1-rc2 on a windows pc, but the result remains the same. This time with 10 mm creapage limit. For me it looks like he can’t go round the slot in a curve, only in a straight line.
This gives an drc error, which is correct
This gives no drc error, despite creepage is something like 4 mm (limit 10 mm)
Then I’d report a bug (help-> report a bug) with a demonstration project attached.
I have sent a bug report #20480
Edit: old post deleted
Oops.
Brainfart. Although I know the differences between creepage and clearance, I still managed to mix them up somehow.
Correct me if I am wrong, but clearance is the connection over air (shortest possible connection between two points) and creepage is the connection over a surface, which can be increased with grooves and slots. So clearance is always smaller/equal than creepage
clearance-creepage
You are right and this bugs me as these terms are quite clear.
I keep meaning to raise a PR to have this fixed but I haven’t quite figured out what a viable suggestion is as an alternative
