Are there OpAmp symbols hidden somewhere in KiCad, or do you create your own?
I would say that they are not so hidden, and I do make my own. As @retiredfeline indicated, look for the part number such as LM324 for example. Many op amps have the same pin connections, and one can serve for many once it is re-named. I like to go for smaller fonts and shorter pins, so I usually edit to make my own symbols.
Because the pinouts for singles are all over the place. And there’s an issue with the supply pins. On duals and quads, it’s solved by adding a unit C or E for the power connections. but that’s really clumsy for a single.
I made my own with generic 741/TL071 pinout and power pins included and solved the input swapping by using a Demorgan equivalent so I can swap the inputs while leaving the power pins where they are.
Has saved me a lot of time and effort.
