Creating isolated GND islands
Hey All,
I am trying to make an isolated GND island with a single connection to an existing GND pin. Creating the island is easy but when connecting with a trace it does not seem to connect with the island with the gnd pin. Has anyone had any luck with isolated GND islands.
First:
Images can be pasted directly into a post. No need to use some external service for this.
Second:
I do not really understand what I’m looking at, or what you are trying to achieve.
Unconnected copper is a bad thing on a PCB, and KiCad does like to do bad things.
You also mention you want to connect it t a GND pin.
Kicad automatically fills zones if those zones can be connected to a pin of the right net.
There is also a lot of information missing from a simple screenshot.
Your problem is much easier to diagnose if you zip up your project and post it here.
Preferably it’s a simplified project which only shows your problem, without a gazillion IC’s and tracks getting in the way.
Maybe what you’re looking for is a net-tie? There are tons of threads about these already, and several footprints in the default library.
Wonder why i did not get a notification in my mail when a reply was posted here.
So what i am trying to achieve here is an isolated GND plane connecting from one point to a GND pin or via. Like so
So here (outlined in white) i’ve created a GND plane for a buck converter connected to J3 directly without mixing it with the existing GND plane. Not sure how it is termed as but you should get the idea.
I did this with the keepout zone, not straight forward to do it. I was looking for an easier way to achieve this.
I have never used net-ties but I suppose that:
is true.
Thank you Net-tie it is.
