I find the hirarchical sheets very useful and would like to know if it is possible to create a hirarchical sheet from an already existing circuit. I select the circuit I would like to have in my hirarchical sheet. Then I select “create hirarchical sheet” and everything is put inside of this sheet and the hirarchical pins are still connected.
I think the only option (in current stable) is to block select and copy. However this will mean you lose the annotation.
Have a read of this:
There is a feature request about
