I would like to let produce a pcb board but when I made the gerber files I found some confused things. I made the gerber file for fsilk. How I can disable the value of the devices in the gerber files?
This are the gerberfiles they need: elecrow.com
Top layer: pcbname.GTL
Bottom layer: pcbname.GBL
Solder Stop Mask top: pcbname.GTS
Solder Stop Mask Bottom: pcbname.GBS
Silk Top: pcbname.GTO
Silk Bottom: pcbname.GBO
NC Drill: pcbname.TXT
Mechanical layer : pcbname.GML
I changed the type from .gbr to gtl, gbl, …
But when I looked at the gerberfiles, the outline I made with Edge.Cuts does not exist.
How I can make the gerber for the holes and vias?
Yes I did that with Edges.Cuts but on the file I don’t see anything.
They say that at least one gerberfile should be the outline. But how I can put two gerberfiles together or can I get the outline on the top layer without changing the layer of the outline.
Is that the mechanical layer?
One dsub connector looks outside the outline. How I can delete these lines from the gerberfile because the pcb should not be greater than 10x10cm
The gerber plotter does only allow you do print silkscreen for ALL components or for NONE.
If you want the DB9 connector without silkscreen you have to edit the footprint with the footprint editor and switch those silkscreen lines to invisible or delete them.
That’s why most people - after a while - start to run their own libraries
As for the Edge Layer (Edge Cuts).. if you SELECT it, it will be in an EXTRA .GML or .GM1 file (that’s the mechanical layer or one of them if you have more than one). If you DESELECT the option it will be in all of the layers you have plotted (.GBT, .GBL, etc.. pp) and NO extra mechanical layer file will be plotted.
From my own experience Elecrow is OK with the Edge Cuts being on a separate layer and that one being called .GBR.
The settings I used for exporting the gerbers for ELECROW - I did not have any non-plated-holes (NPTH) though:
