Continuing the discussion from Creating arc shaped tracks:
I’m using KiCAD 7.0.10 and I still don’t see options for this. Is there a way to do this yet? I can draw arcs, but assigning them to a net seems impossible.
I don’t want to use plugins.
There is some support, but it is basic. Arcs only, no beziers.
While drawing track, Right Mouse Button > Track Cornering Mode or hotkey Ctrl + /.
If you rule out plugins I see 3 options left:
See my attached video…
Support for this is still very minimal in KiCad.
You can use the Create from Selection / Create Tracks from Selection to turn a selected graphical arc in to a track, but this also turns the “arc” into a “fillet”. With such a fillet it is difficult to keep it’s center at the same location when you change it’s radius. It’s one of those things that I sometimes think about for making a feature request on gitlab for improvement, but before I do that I first have to get acquainted with KiCad V7.99. Apparently it’s possible to assign a net name to graphical objects in KiCad-Nightly, and that would already be a noteworthy improvement in this area. But I’ve just gotten a recent V7.99 working and I have not yet had time to experiment with this.
Great news: KiCAD 8.x is out, and it supports this natively.
Just select an arc or other shape, press E for properties and select a net from the list.
