Quite often, I find that I need a “hotspot” for copying/moving that KiCad fights me on.
For example, in the footprint “PinHeader_2x10_P2.54mm_Vertical”, I want a hotspot dead center. This would be a spot equidistant from pads 9, 10, 11, 12 and has nothing around it at coordinate (1.27, 11.43).
What I often do in other programs is to create a little “L-shaped” corner in Silkscreen (or a mechnical layer), and that corner is enough to create a “hotspot” that I can grab and use for alignment if I select the layer.
Unfortunately, the same trick doesn’t seem to work in KiCad. Am I missing something? Or is there a different workaround?
Thanks.
