Create pad from shape Footprint editor
I’m having trouble figuring out the best practices for creating a footprint for an RF shield. I am using Masach MS329 and MS409 specifically.
I imported the DXFs from Masach website but because the corners are rounded. How do I turn those rounded corners into Pads?
I see other posts about “create pad from shape” but I don’t see that option anywhere? was that an older version of KiCad
Also, How can you make a Courtyard that allows parts to be placed underneath the shield. I created a courtyard shape that matched this F.Cu layer, but in the layout tool placing anything within the shield created errors
If it were me, I’d leave off the Courtyard.
Open footprint editor.
Use tools to create a graphic shape (or import a shape) on the top or bottom layer.
Place a small SMD pad on that graphic shape.
Right mouse click on the pad (or hotkey Ctrl + E )
Select “Edit Pad as Graphic Shape”
Finish with another Ctrl + E.
That works, thanks I have read other posts that said “Edit Pad as Graphic Shape”
I thought that meant to actually Edit the Pad to match the Graphic Shape.
I think a better description of what happens when you press the last “CTRL+E” would be labeling that feature as “Merge Shapes” or “Merge Pad to Shape”
I also agree, about leaving off the Courtyard because you can’t place on this ground and the normal clearances should be enough.
Thanks
