HI,
I need to rate the slopes.
I installed the “Rounder for Tracks version 2.1” plug-in, but they failed to make it work. place the mistakes it gives me.
My KICAD:
Application: kicad
Version: (5.1.2)-1, release build
wxWidgets 3.0.4
libcurl/7.61.1 OpenSSL/1.1.1 (WinSSL) zlib/1.2.11 brotli/1.0.6 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) nghttp2/1.34.0
Boost: 1.68.0
Curl: 7.61.1
Compiler: GCC 8.2.0 with C++ ABI 1013
timestamp_t is defined in the KiCAD source code in common.h
timestamp_t
typedef uint32_t timestamp_t
timestamp_t is our type to represent unique IDs for all kinds of elements; historically simply the timestamp when they were created.
Long term, this type might be renamed to something like unique_id_t (and then rename all the methods from {Get,Set}TimeStamp() to {Get,Set}Id()) ?
Definition at line 56 of file common.h.
It looks like you can get a timestamp using pcbnew.GetNewTimeStamp().
This might be as simple as replacing tsc in that code with pcbnew.GetNewTimeStamp(), assuming tsc is not used elsewhere. If that doesn’t work, try replacing wherever tsc is assigned with tsc = pcbnew.GetNewTimeStamp(). Note that this assumes that python file is using import pcbnew. If it instead is using import pcbnew as pn or something else instead of “pn”, then use whatever is after the as, like this: pn.GetNewTimeStamp()
pcbnew.TimestampDir
<function TimestampDir at 0x000000000beaa320>
[x for x in dir(pcbnew) if 'stamp' in x.lower()]
['CTL_OMIT_TSTAMPS', 'GetNewTimeStamp', 'TimestampDir']
1595442964
pcbnew.GetNewTimeStamp.__doc__
'GetNewTimeStamp() -> timestamp_t'
