Hi all,
in the recent days I’ve made good progress on my PCB thanks to the community helping me with “blockers” that did turn up - which is expected, since I’m a KiCad/PCB newbie.
For the remaining problems, I’ve decided to separate and simplify each one in a dedicated PCB (“bisecting”).
I also selected a manufacturer (Aisler) and PCB stack up (“Aisler complex 4-layer ENIG”).
Again, I would highly appreciate any hints or tips rgd this post! Thank you!
The final design will have 2 RF PCB antennas, left & right over a big ground plane:
These antennas seem to be called “planar helical”, and they span both the front and bottom Cu layers, they do not use inner Cu layer, but they do use vias (obviously).
My problem is: currently, the antennas switch material on every turn, from “bare Cu metal” to “ENIG plated Cu”.
I want to avoid that and have the complete antennas all ENIG.
Plus, ideally have a reusable footprint for the antenna (in left and in right orientation … like in the rendering above).
How do I do that?
I’ve tried the footprint editor, but I cannot freely draw but have to use the pad shapes available, which I can tweak, but it doesn’t get me to the shapes I need.
My assumption would be: if I had a footprint with basically a single complex shaped pad, that pad could be ENIG only.
I’ve also tried to define a net class “Antenna” in the the hope I could then just assign that to my currently hand-drawn (non-footprint based) antennas, and then define “ENIG finish” on that net class - but I couldn’t find any place where I can change the finish on net classes.
I should also mention: the antennas should also have no solder mask on the traces - which would automatically happen in footprint pads?
I also read docs, searched this forum, searched the web, and even asked ChatGPT;) No luck.
So again I’m at a junction where a hint/tip would be awesome!!
