Apologies in advance for a question I feel is probably second nature to most in this forum… I’m respinning a few of my existing designs to SMD to sacrifice while I learn how to use my new reflow oven correctly.
If I take a component like a 2N7002 MOSFET or BC857 I see in the datasheet its footprint is SOT23 (or TO-236AB is also mentioned in the 2N7002 datasheet as an equivalent). In KiCad I don’t see those in either Transistors_SMD or any of the Housings_xxx libraries.
I’m thinking that’s a very common footprint, so must be there somewhere. Is it, but under a different naming convention? Using 2015-05-12 BZR5652 from the Windows launchpad.
Maybe verify against the entire list available here to see if you have the full compliment of libraries available? https://github.com/KiCad/kicad-library
Package style or case style are the terms most commonly used in data sheets. What would lead the developers to pick a different term? I wonder how many other non-standard descriptive terms are confusing new users.
