I wanted to copy the BC847 symbol to my own lib for vendor ID code, but I got me this problem.
I understand what it means. I also found a workaround. I found out that it was derived from a BC817 and that one I saved it as a bc847 in my own library. Only after that I could change the fields with 817 into 847
This is sorta annoying. Is there an other workaround for copying derived symbols?
Regards,
Bas
Instead of saving the symbol have you tried exporting it to your own library? Seems to work for me. I get a BC847 added to my library without any parent.
That issue was raised for v6 though. Don’t know whether it was addressed or not, didn’t go down the rabbit hole.
jmk
August 6, 2023, 1:05am
5
That “issue” has existed forever. If the symbol was in italics it could neither be “copied” nor “saved as”, even back in the days of 4.
Well, as I wrote, exporting the symbol to my own library worked for me, so maybe it got “fixed” as a result of other changes.
--- a.kicad_sym 2023-05-14 22:45:17.031951244 +1000
+++ b.kicad_sym 2023-08-06 11:15:38.605617469 +1000
@@ -2916,6 +2916,86 @@
+ (symbol "BC847" (pin_names (offset 0) hide) (in_bom yes) (on_board yes)
+ (property "Reference" "Q" (at 5.08 1.905 0)
+ (effects (font (size 1.27 1.27)) (justify left))
+ (property "Value" "BC847" (at 5.08 0 0)
+ (property "Footprint" "Package_TO_SOT_SMD:SOT-23" (at 5.08 -1.905 0)
+ (effects (font (size 1.27 1.27) italic) (justify left) hide)
+ (property "Datasheet" "http://www.infineon.com/dgdl/Infineon-BC847SERIES_BC848SERIES_BC849SERIES_BC850SERIES-DS-v01_01-en.pdf?fileId=db3a304314dca389011541d4630a1657" (at 0 0 0)
+ (effects (font (size 1.27 1.27)) (justify left) hide)
+ (property "ki_keywords" "NPN Small Signal Transistor" (at 0 0 0)
+ (effects (font (size 1.27 1.27)) hide)
+ (property "ki_description" "0.1A Ic, 45V Vce, NPN Transistor, SOT-23" (at 0 0 0)
+ (property "ki_fp_filters" "SOT?23*" (at 0 0 0)
+ (symbol "BC847_0_1"
+ (polyline
+ (pts
+ (xy 0.635 0.635)
+ (xy 2.54 2.54)
+ (stroke (width 0) (type default))
+ (fill (type none))
+ (polyline
+ (pts
+ (xy 0.635 -0.635)
+ (xy 2.54 -2.54)
+ (xy 2.54 -2.54)
+ (polyline
+ (pts
+ (xy 0.635 1.905)
+ (xy 0.635 -1.905)
+ (xy 0.635 -1.905)
+ (stroke (width 0.508) (type default))
+ (polyline
+ (pts
+ (xy 1.27 -1.778)
+ (xy 1.778 -1.27)
+ (xy 2.286 -2.286)
+ (xy 1.27 -1.778)
+ (xy 1.27 -1.778)
+ (fill (type outline))
+ (circle (center 1.27 0) (radius 2.8194)
+ (stroke (width 0.254) (type default))
+ (symbol "BC847_1_1"
+ (pin input line (at -5.08 0 0) (length 5.715)
+ (name "B" (effects (font (size 1.27 1.27))))
+ (number "1" (effects (font (size 1.27 1.27))))
+ (pin passive line (at 2.54 -5.08 90) (length 2.54)
+ (name "E" (effects (font (size 1.27 1.27))))
+ (number "2" (effects (font (size 1.27 1.27))))
+ (pin passive line (at 2.54 5.08 270) (length 2.54)
+ (name "C" (effects (font (size 1.27 1.27))))
+ (number "3" (effects (font (size 1.27 1.27))))
(symbol "Boost-converter" (pin_names (offset 1.016)) (in_bom yes) (on_board yes)
(property "Reference" "U" (at 0 -2.54 0)
BobZ
August 6, 2023, 1:30am
7
Is this observation symbolic of something?
jmk
August 6, 2023, 1:33pm
11
retiredfeline:
Hi, we’re all busy discussing different functions.
The tally so far:
Copy - doesn’t work
Save As - doesn’t work
Export - does work.
Question.
I was just looking. And it seems if I use the export option the symbol is going to be stored as it’s own library.
If I would like to store the transistor as a symbol inside any of my already existing libraries, would that be possible? I haven’t tried anything yet. Can you use import for that or something?
Regards,
Bas
Nope, I could store in my existing (personal, writable) library. Try again.
I was afraid of deleting all my hard work. Can you imagine?
I am gonna make a backup and try it out
Try again
Well… I did. I hit export and selected one of my libraries.
Than this happened. The amount of luck I sometimes manage to find me
howcan?
EDIT:
Despite the error the symbol is actually exported. So it does work
Bas
You have some kind of permission problem on the library file.
jmk
August 7, 2023, 8:09am
17
Hi @bask185
I get the same warning, but Export still works.
Kicad 7.0.6 / Linux Mint.
system
Closed
November 5, 2023, 8:09am
18
