Hey!
I have three tracks which need to be a bit bigger here and there.
So I have a netclass for them, specifiying the min clearance and trackwidth.
I than placed a copper zone over one track, assigned it to the net and draw a huge rectangle.
doubleclick, it fills, and looks good.
When I do the same with next track, the copper layers will be too close, even touching each other. DRC will show that when I click it. But it does not interfere when these coppeplanes where made. I have the option active that I should not be able to violate DRC while routing.
If the zones are touching or very close you may have to set up the Zone priority level.
Off the top of my head its in the properties box for the zone, near left bottom I think.
You can set this to different numbers, the higher the number the higher its preference. So a zone with preference 1 will get poured before a zone with a preference of 0. The second zone will then adhere to the DRC rules.
I think this is correct, not at my pc to check.
