I have a high power SMD LED that I am designing a footprint for. It has 2 pads either side of the LED, then the die in the centre itself needs a pad for thermal relief (the die is located where the “LED” text is below). Annoyingly the die’s pad is tied to the LED anode so I cannot use a normal layout editor copper pour. These are the pads:
Basically I want to do a copper pour within the courtyard that does not touch the pads. I don’t want to have to draw a polygon with pad-shaped cutouts in.
Is it possible to do a copper pour in the footprint editor?
BTW the footprint is 20x20mm.
Is there some alternative like I create a 3rd pad which I can manually copper pour later in layout editor? I’d appreciate any ideas. Thanks.
Basically I want to do a copper pour within the courtyard that does not touch the pads. I don’t want to have to draw a polygon with pad-shaped cutouts in. Is it possible to do a copper pour in the footprint editor?
Unfortunately thats the way you have to go.
Additional thought: you wrote "the die’s pad is tied to the LED anode " - so the polygon could have a connection to Pad2 - hence a simple rectangle is enough (avoiding the complete left side with the Pad1-GND-cathode Pad).
I think you’re misreading the (somewhat crappy) datasheet. I don’t think the middle arrow attached to the “Copper” callout is pointing to the diagonally-hatched area, but rather to the 6mm circle in the middle.
I’m not sure what the diagonally-hatched area is suggesting, though, and a larger thermal pad would certainly make sense.
I agree: the arrow seems to point to the circle which has similar texture than the two other pads. I interpret the hatched area as a continuous copper fill but covered with mask. It’s connected to the circular pad. It’s only a suggestion; in reality you want as large continuous copper area as possible. The idea is of course transferring heat as much as possible. You should just add a large zone around the circular pad (in the PCB layout), with “solid” connection without thermal spokes.
