While I know that there is a clearance setting from tracks to copper pour (GND fill zone) is there a clearance setting between two copper pours planes (fill zone) on the same side, for example GND on the main one and 0Vdc the minor plane? Or do I draw the minor plane with reduced dimensions?
It’s OK. I think that I did found it.
If I select the fill zone (copper plan) and select “clearance” to say 1mm
