Converting radiused corners to polygons
I’m creating a footprint for a ti H-Bridge using a VQFN-HR (16) package, setting out the solder resist mask and the solder paste layers are causing me some issues . . .
https://www.ti.com/lit/pdf/mpqf631b
Where I 'm having issues is with the radiused corners of the solder resist mask apertures, for example Pad 4 . . .
I have the pad and a square cornered mask but this is not technically correct . . .
So I converted the polygon to lines then added a correct 0.05mm rad to the relevant corners and then converted the shape back to a polygon . . . and got this . . .
What were rads are now a mix of rads and chamfers, it’s not very pretty.
Is this a known issue ? am I doing something wrong ? is there a workaround ? this is on 8.0.1 latest release build for Windows.
What I have though about doing is making this feature from 3 pads, one central rectangular one with square corners and two smaller ones, one at each end with radiused corners.
As far as I know there is no open gitlab issue regarding this behaviour on gitlab. It looks like a arc approximation artefact. Remember the used radius: 0,05mm
It’s not really possible to produce such a small radius as a “real” shape - the produced result will always differ from a ideal 0,05mm sized arc.
If you repeat your shape modification / shape creation commands with a 0,25mm arc radius you will get better looking results (albeit still not perfect).
This approach will work. You could even work with only two pads (one long from left<–>right, one from top<–>bottom) overlapping each other. This allows easy pad placement - both share the same pad coordinate point.
I get nice rads on pads when specified as Rounded Pads . . .
I’m making progress regardless . . .
Good point :+1:
yes, pads seem to have nearly perfect round edges, even with very high zoom factors.
I think there are two different code paths internally, one for pads and one for polygon/arc calculation (with much less approximation accuracy).
As always: if this annoys you enough → gitlab :slight_smile:
It took me some minutes you likely mean radii when you write rads. I already guessed it was not radio active and suggestions of Reactive Attachment Disorder or Reactive Airways Dysfunction Syndrome also seemed implausible. Using unusual abbreviations on a public forum is not a very good practice. It also degrades search results on this forum.
There are already a bunch of related open issues on gitlab related to polygon geometry.
If I were to make this footprint, I would use multiple overlapping pads with the same pad number. This would have no issues with rounded corners.
Yup, this is what I have done . . . it’s close enough for now.
I’ll see if any of those existing issues fit with what I’m seeing, if not I’ll probably open an issue.
Sorry, it’s a standard engineering term for radius here in the UK so didn’t give it much thought, but yes I do agree with your point.
0.05mm = 0.002 inch. You won’t find any PCB vendor that can do that.
An average Human ‘Hair’ is 0.003 inches thick.
but it is round at least.
Basically, confirming @mf_ibfeew
I have no problem drawing 0.05mm Radius - it shows clean radius until it’s placed over Cu, then it (the Aperture) shows Straight (Chamfered) line. A graphics thing and not necessarily a PCB thing…
EDIT: Correction - the Straight-Line happens when converting from Polyline to Filled Polygon. That said, after playing around, I discovered that Setting the Line-Width (on a corner that does not have a Radius Corner) will present a Radius’d corner based on the Line’s width… Last TWO Screenshots, below… Thus, if making a Rectangle, user can create a Radius’d Corner by tweaking the Line Width and Filling the Rectangle will keep that desired result. Last Screenshot has 0.1mm line-width on an Aperture with 0.52mm Width
EDIT - UPDATED / CLEAN-UP: What is the Smallest possible Aperture in a Mask?
I was able to dial-it-down to very small, too small to see the Radius’d corners in the 3D-Viewer so, I increased the size to be able to see them.
Line-Width = 0.01mm. Last image shows Radius’s corners. Aperture Width=0.035mm
Screen Shot 2024-04-22 at 13.23.29
