I may have accidentally added dxf support when refactoring the other commands a little
which is the command to avoid contours? I see the parameter here
--use-contours
Woops, I fixed it
No, we have been working solely on KiCad file formats. There were some other projects to convert Altium formats to KiCad but Iâm not sure on the status on those.
You likely want to quote this so the shell doesnât expand it to files in the current directory
--layers '*'
Maybe consider using all instead?
--layers all
heh, things you donât think about when you exclusively use Windows :3
* isnât the only concern then, there are other patterns like *.Cu as well
Thanks!
And can you add sch export to svg option?It will be very useful.
Schematic is harder due to codebase structure, I want to, but Iâm not sure how far Iâll get.
Just do it! @marekr
If some components in schematic can not handle temporarily, just ignore it.
I will test sch to svg option at the first time.
Thanks!
BTWďźI still can not use --layers * option with the latest 6.99. Kicad report:
Invalid layer name â*â
At least one or more layers must be specified
BTW, I think if export pcb to svg and set the background color of svg to black will be very helpful.
In svg tag add style = "background-color:black"
svg export of schematics is added.
@marekr Great Job! Thanks!
I have tested svg export of schematics, it works. But if I specify svg file name with -o option, kicad export a subfolder and the svg file is in this folder.
By design at the moment. It generates an SVG per page/sheet of the schematic.
Fixed the missing * option
Thanksďź
How about supporting import option with kicad-cli tool? @marekr
I want to import altium designerâs pcbdoc and schdoc file to kicad with kicad-cli tool.
I have used the import function from Kicad GUI menu, and it can import pcbdoc and schdoc to kicad.
@marekr
Not in v7. Maybe v8 in 2024.
kicad-cli from Kicad v7 already exports SVG images of Schematics and PCBs
Here I have a simple script that does that one page/layer per file. Cheers!
