Continuing a track at inactive layer
One problem I always have, is that if I have top layer active, and I want to continue a track on the bottom layer, I have to change layer first.
If I am routing tracks, and click a track, that means I am routing just that track and nothing else. It is too easy to create stray coppers.
Ok, I started a track on F.Cu, clicked the mouse to fix the end of the track, then typed V to create a via, then clicked the mouse to continue the track on B.Cu, and so on. Is this not what you want?
No not really. Lets say, there is an end of unfinished track somewhere on lets say bottom layer, and I am on top layer, and routing. If I then click an end of that (bottom layer)track, what else would I want than continue that bottom layer track.
Now it is done so that I first have to change to a correct layer, and then start routing again (X I think). Too, often I create stray copper, too. Which must be cleaned away…
I have no experience with incomplete tracks but sounds like you should write a feature request on Gitlab.
I have too many accounts at various services. And I have no idea how it should be done.
Do you always route a track completely at one go. Or how should I say it. I sometimes have to stop in the middle of routing, and do something else.
I haven’t done enough routing for it to be a significant time sink for me as making PCBs is only a hobby. Put in that feature request, we’re mostly forum readers here and not devs.
I don’t know why, but for me it behaves just like you describe you want it to behave. I seem to have version 6.0.1 in this machine.
EDIT: I just tried with the latest nightly build. It behaves identically. I have two tracks with loose ends, one on F.Cu and one on B.Cu. No matter which layer is active, when I start routing over an existing loose end, that track is continued and the corresponding layer becomes active if it wasn’t already.
Strange. I wonder which setting is different. This is a Windows 10/64 and KiCad 6.0.7
