I used the Connector_PinHeader_2.00mm:PinHeader_1x10_P2.00mm_Vertical_SMD_Pin1Right
This footprint is in the standard library my board has been produced and now I’m trying to find a connector. I assumed that since it was in the standard library it would be an easy to find connector but now I’m not sure.
Does anyone have a go to connector for this footprint or know of one that works?
The fact that it’s in the standard library says nothing about its availability on the market. In fact many of the multiple pin footprints are automatically generated. It may or may not be easy to get a connector of N pins where N is some arbitrary number.
Usually people start from the other direction, they look for a connector that suits their design in characteristics (shape, number of pins, spacing, orientation) that can be purchased from the retailer of their choice, then they look for a footprint or make one, and maybe ditto for a 3D model.
They have selection drop downs. Good luck.
EDIT: hmm. Looks like their smd’s are all double row. Probably makes sense from a mechanical connection stand point.
EDIT 2: Just looked at the footprint. You MIGHT be able to use a 20 pin, 2 row socket and not use all the pins if push comes to shove.
