I have a strange problem.I need connect 2 points (or 2 objects) with 2 traces (1 Bottom 1 TOP) because there is much current. Usually this is very easy but today in the same circuit i can connect some points like i want, but other points i can’t to connect with 2 trace:
It means after i drew the first trace (for example in TOP) when draw the second trace (Bottom) Kicad cancels the first trace. (TOP)
Does anyone know why?
The points are through holes
Under ‘Route’ menu click ‘Interactive router settings’.
Turn off the highlighted option.
Thank you very much!!!
