So I just about got to grips with the PcbNew Module libraries and now another spanner is in the works.
I have an existing design and decided to add a micro onto the circuit rather than on a separate board.
It seems that the microchip PICxx devices have to be added by hand, as they are not entered automatically.
Is this intentional or some kind of bug under Windows7 64 bit?
PCBnew only holds the footprints, e.g. a 26 pin DIP package, it is in the schematic where it holds the pinouts of most PIC microcontrollers, and describes the functions of the pins.
The following libs (that should be on your system) are available:
microchip_pic10mcu.lib
microchip_pic12mcu.lib
microchip_pic16mcu.lib
microchip_pic18mcu.lib
microchip_pic24mcu.lib
microchip_pic32mcu.lib
They might not be added to your projects automatically. (Only a few of the “installed” libs are added by default.)
But they should exist in kicads system directory. (/usr/share/kicad/library under linux. somewhere under c:/ for windows.)
You can add them to your project manually. If you want them included in all your projects you have to add them to the default template. More details in this old thread:
I did eventually find them. I was misled by the fact that the PcbNew footprint wizard loads up absolutely everything by default, so I expected that the eschema library would do similar things. Wrong again!
