Help? I’m not sure how to proceed. I have PWR_FLAG on GND elsewhere, and when I deliberately add it to the GND on C7 I get even more ERC errors.
ERC report (5/5/2019 10:29:34 PM, Encoding UTF8 )
***** Sheet /
ErrType(4): Conflict problem between pins. Severity: warning
@(203.20 mm, 120.65 mm): Pin 2 (Passive) of component C7 is connected to
@(74.93 mm, 184.15 mm): pin 1 (Unspecified) of component U4 (net 4).
***** Sheet /Obstruction detector/
@(74.93 mm, 184.15 mm): Pin 1 (Unspecified) of component U4 is connected to
@(62.23 mm, 41.91 mm): pin 1 (Power input) of component #PWR06 (net 4).
@(74.93 mm, 128.27 mm): Pin 4 (Unspecified) of component U4 is connected to
@(93.98 mm, 115.57 mm): pin 2 (Passive) of component R25 (net 92).
@(77.47 mm, 128.27 mm): Pin 3 (Unspecified) of component U4 is connected to
@(87.63 mm, 128.27 mm): pin 2 (Passive) of component R23 (net 95).
** ERC messages: 4 Errors 0 Warnings 4
Here’s the project file:
https://www.mediafire.com/file/t2b9hc93xech3b6/SecureCoop_Pi_daughterboard.zip/file
