Hi All,
I have a weird issue with the layout (Kicad 5.1.6 on MacOS High Sierra). I never experience that until now and I didn’t find a fix.
For some reason, after loading the netlist and placing the components in layout, when routing I noticed the mouse did not jump on pad centre; so the manual routing become more complicated because the end of trace is not closed on the pad (see in the image); I assume that I alter some settings (the position difference is under 0.2mils).
I cannot figure out how to fix that; the packages are made correct with higher than 5mils grid. Can you please help with a suggestion?
Thanks and Most Appreciate your feedback,
Best Regards,
Andrei
