Hi
I downloaded a full kicad project from the github repo held by a friend of mine (as we need to work together on this very same project)
… and when I tried to modify some aspects of the design (on EEschema, I insist), I discovered that abolutely NO component or wire was snapping to grid. In fact, it looks like the whole grid was shifted by half the value of the grid step.
It’s definitely not a “bad component design”, as all component are comming from the official kicad repo. No exotic stuff, just resitors, op amp, caps etc.
Could it be a compatibility problem between two different releases of Kicad? did someone stumbled on the same problem ? is there an “secret magic order” to change the origin point of the grid ?
Thanks for reading
Marc
