Hi all,
I am looking to design a daughter board which will replace an existing PCB. This daughter must interface with two stacking board-to-board connectors aswell as mounting holes so is a direct replacement to the current solution. The existing design files for the current board are no longer availible but i do have the gerbers (no position/centroid file).
Is it possible to extract the coordinate locations for the two stacking connectors directly from the current gerbers in gerb view?
Can gerb view also provide drill positions or am i best deciphering the excilon drill files?
If there is an alternative more suitable approach of course open to suggestions!
Thanks in advance.
Mike
