Just started with Kicad, and I am a bit stuck. I started a new schematic with the MCU of my choice, STM32F446VETx, and the component is so huge that it takes up the entire page (A4). Tried the component editor, this allows to add pins and change labels etc, but not the outline of the entire component. What am I doing wrong?
I suspect this has an easy solution, but so far I have been unable to find it.
I assume the outline is a rectangle.
move your mouse pointer over one corner and press g for grab.
You should be able to edit this rectangle.
By the way: It might be a good idea to change the symbols to a multi unit symbol.
This way you have more freedom when creating your schematic.
If you meant you want to change the border of the page:
You can do that under file->page settings in the schematic editor. There you should be able to change the page size to for example A3.
Your pin-names are very long. I would delete all the information except the pin name (Example delete everything except PB1)
To make my point clear: here some of my mcu symbols. (One of them is a stm32f4 maybe you can use it as a starting point.) tera_processors.lib (9.7 KB)
I think the symbol library needs more moderators. There are currently over 100 pull requests open. Maybe somebody already changed the symbol but it never got merged.
I would design my own symbol. Takes half an hour and you get a usable symbol out of that.
Who says that the symbol is correct otherwise. (If it looks bad maybe it even has bugs like wrong pin numbers, …)
Grab kind of works, but all I can do is position the whole rectangle, not resize it. But I will have a look into you library and consider making this a multi unit symbol or just a smaller with just the pin functions I intend to assign.
BTW, thanks everyone for the nice and quick answers!
I see nothing technical wrong with the screenshoot.
That just because it has tons of text.
On my MCU symbols I just use “PA0, PA1, PA2,…” Thats all I need.
So I guess it has a good chance of being correct, but probably has not been checked by a human. Whatever the source, careful checking of symbols is always advised.
That is me. This was my procedure with the PCB design tools I was using a few incarnations ago. I have not yet used KiCAD on a project containing a uC. (Unless you count the one board that included one of the smaller Arduino modules. The Arduino world has already gutted the pin names to make nearly-meaningless short designators like “PB0” thru “PB7”, etc.) It has been said before (and not only from me):
Learn to make symbols and footprints using the editing tools!
I don’t have measurements to support the idea but I’d say that a symbol or footprint which looks bad, has a higher probability of containing more serious errors. Processors in general - from the basic PIC 8-bit chips on up - are a drafting challenge because they have oh-so-many pins with oh-so-similar names.
That’s how i do a lot of things. Some actions are not really efficient using the graphical interface.
Some of us even use python scripts for some tasks. (generating footprints, generating on board antennas, …)
Here is a tip: I use kipart to create stm32 mcu symbols. It supports the pinout csv file exported from stm32cubemx application. It will generate each port as a separate symbol. It will use only the function you have selected for the pin name. So you can have a symbol like this:
