I generated a net list from the schematic. But when I load the net list, it shows
Info: Using references to match components and footprints.
Info: Checking netlist component footprint "D1:/57D44213:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D2:/57D4577F:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D3:/57D45C20:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D4:/57D45C6D:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D5:/57D44308:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D6:/57D4578B:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D7:/57D45C2C:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D8:/57D45C79:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D9:/57D444D8:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D10:/57D45797:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D11:/57D45C38:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D12:/57D45C85:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D13:/57D444E4:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D14:/57D457A3:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D15:/57D45C44:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D16:/57D45C91:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D17:/57D44674:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D18:/57D457AF:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D19:/57D45C50:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D20:/57D45C9D:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D21:/57D44680:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D22:/57D457BB:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D23:/57D45C5C:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "D24:/57D45CA9:Diodes_THT:Diode_DO-41_SOD81_Horizontal_RM10".
Info: Checking netlist component footprint "J1:/57D4A05A:local:jumper".
Info: Checking netlist component footprint "J2:/57D49FBD:local:4pin35mmAudio".
Info: Checking netlist component footprint "J3:/57D4A13F:local:jumper".
Info: Checking netlist component footprint "R1:/57D527EC:local:RESISTOR".
Info: Checking netlist component footprint "R2:/57D4D4E2:local:RESISTOR".
Info: Checking netlist component footprint "SW1:/57D441DE:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW2:/57D45779:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW3:/57D45C1A:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW4:/57D45C67:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW5:/57D44302:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW6:/57D45785:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW7:/57D45C26:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW8:/57D45C73:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW9:/57D444D2:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW10:/57D45791:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW11:/57D45C32:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW12:/57D45C7F:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW13:/57D444DE:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW14:/57D4579D:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW15:/57D45C3E:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW16:/57D45C8B:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW17:/57D4466E:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW18:/57D457A9:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW19:/57D45C4A:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW20:/57D45C97:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW21:/57D4467A:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW22:/57D457B5:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW23:/57D45C56:local:MXALPS_FLIP".
Info: Checking netlist component footprint "SW24:/57D45CA3:local:MXALPS_FLIP".
Info: Checking netlist component footprint "U1:/57D48AE5:local:TEENSY_2.0".
Changing component "U1:/57D48AE5" value from "" to "TEENSY2.0".
Info: Checking netlist component footprint "U2:/57D4E136:local:HOLE".
Info: Checking netlist component footprint "U3:/57D4E261:local:HOLE".
Info: Checking netlist component footprint "U4:/57D4E2F6:local:HOLE".
Info: Checking netlist component footprint "U5:/57D4E38F:local:HOLE".
Info: Checking netlist component footprint "W1:/57D52188:local:JUMPER_SMD_2DUB".
Clearing component "W1:/57D52188" pin "2" net name.
Changing component "W1:/57D52188" pin "1" net name from "xtradata" to "Net-(W1-Pad1)".
Info: Checking netlist component footprint "W2:/57D4F9E1:Wire_Pads:SolderWirePad_single_2mmDrill".
Error: Component 'U1' pad '15' not found in footprint 'local:TEENSY_2.0'
Error: Component 'U1' pad '16' not found in footprint 'local:TEENSY_2.0'
Error: Component 'U1' pad '17' not found in footprint 'local:TEENSY_2.0'
Error: Component 'U1' pad '30' not found in footprint 'local:TEENSY_2.0'
Error: Component 'U1' pad '31' not found in footprint 'local:TEENSY_2.0'
Error: Component 'U1' pad '13' not found in footprint 'local:TEENSY_2.0'
Error: Component 'U1' pad '14' not found in footprint 'local:TEENSY_2.0'
