Im using Kicad for the first time. I need to create a LED-Bargraph. I try to draw the schematic symbol in the kicad component editor. The bargraph has 20 LEDs. Is there no way to copy the diode symbol ? I don’t find a copy function at all in the component editor.
What kicad version do you use? The symbol editor got a massive overhaul in nightly so this is quite an important information for us to help you properly.
It’s there but not very intuitive, hopefully it is one of the things they fixed for V5.
Draw a selection rectangle around the items you want to copy after you release the mouse button you can then drag the items to a new location. Then right-click and select “Block Copy” to place a copy. A left click will move the items instead.
Yes this is the expected behavior for kicad version 4.
While the selection moves with your mouse press the right mouse button and select copy block. You will notice that now the thing that moves with your mouse is a copy of the original.
