In EAGLE there was a handy way to complete a track routing placing the last segment orthogonal to the target. Example:
Starting from the left pad (SDA1) I want to go straight (horizontally) to the already routed vertical track on the right. The current grid does not allow a “natural” path for this, the nearest grid intersections are slightly above or below the horizontal projection.
I’m aware I can:
- change the grid settings
- use the “free-angle” mode (press CTRL)
- edit the segment properties and change the coordinates manually
I’m asking if there is another modifier (shortcut) just to extend the current track and join it horizontally (or vertically).
Version: 8.0.2-8.0.2-0~ubuntu24.04.1, release build
wxWidgets 3.2.4
FreeType 2.13.2
HarfBuzz 8.3.0
FontConfig 2.15.0
libcurl/8.5.0 OpenSSL/3.0.13 zlib/1.3 brotli/1.1.0 zstd/1.5.5 libidn2/2.3.7 libpsl/0.21.2 (+libidn2/2.3.7) libssh/0.10.6/openssl/zlib nghttp2/1.59.0 librtmp/2.3 OpenLDAP/2.6.7
Platform: Ubuntu 24.04 LTS, 64 bit, Little endian, wxGTK, X11, ubuntu, x11
Date: Apr 28 2024 21:38:32
wxWidgets: 3.2.4 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.83.0
OCC: 7.6.3
Curl: 8.5.0
ngspice: 42
Compiler: GCC 13.2.0 with C++ ABI 1018
