I teach KiCad and every year, at least one student takes someone else’s project, modifies it and tries to pass it as their own. I catch them most of the time, but not always. So I thought I may be able to detect such files by comparing UUIDs. Basically, I’d dump all component UUIDs from all projects and then search for duplicates. If I understand from the docs correctly, UUIDs are preserved even when moving projects between different operating systems, changing project name (Save As) etc.
Would that work? Are there any caveats I should be aware of? Should I compare entire UUIDs (128 bits) or only certain blocks? I tried googling for scripts or tools that would do this, but found none. Thanks.
Edit: I made a Windows PowerShell script that detects similar projects, you can get it here:
KiCad uses the UUID’s to match schematic symbols with PCB footprints. So at least those UUID’s normally don’t change. However, if a (part of) a schematic is cut, and then Paste Special is used to re-insert that section on another (hierarchical) sheet, you have to preserve the RefDes, and t hen re-synchronize with the PCB using the RefDes. When the parts (block) is inserted in the other sheet, the UUID’s change.
No, as I was writing above while you posted, UUID’s are changed when a circuit (section) is pasted. UUID’s would not be unique if there are duplicates. The sole purpose of an UUID is to be unique.
In KiCad, every object has an UUID, even wire segments and junction dots. I don’t know what’s the use of that, never looked into details but it does seem a bit exaggerated to me (and it increases file size).
KiCad’s file format is in the form of S-expressions and most programming languages will have some library to read such files into memory with just a few lines of code. The whole Idea behind UUID’s is that they have so many bits that the chance on collisions is negligible. When you reduce the amount of bits you check, the chance on collisions increases. In a moderately small project of mine, there are around 500 UUID’s in the schematic, and 7000 UUID’s in the PCB file. Is it a performance problem to check such a number of UUID’s in between the students work? (or do you want to cross check with other year’s work, or whole github?) Checking only part of the UUID seems premature optimisation to me. Start by using standard checks, optimize only if needed.
So even individual symbol and footprint primitives (lines, polylines etc.) get new UUIDs whenever they are placed into the project? That sounds promising. Students turn in 30 to 60 projects every year and they tend to be simple. If I limit the dump only to component UUIDs, it will be a few thousand entries at maximum.
I looked at KiCad’s internal Python script examples, but TBH their syntax looks… daunting. Moreover, I need the script to search a given directory and subdirectiores and dump UUIDs from all kicad_sch and kicad_pcb files it finds. Will standard methods like os.listdir() or modules like glob() work in internal Python? Any tips which class I should then use to get the UUIDs? (The search field at the official KiCad Python docs page searches only their names, not fulltext.)
I would not do this with internal python scripting, but write a separate program for it.
As I previously posted, reading an S-expression based file from disk is just a few lines of code.
With a command line program, you can easily script it. Maybe you want to create a (sort of) database which holds all the UUID’s extracted from past years and of multiple classes of students.
As your only concern is to find plagiates and there is no intention to further modify or even interact with those projects, I also do not see any benefit for using Python inside KiCad for this. Have you looked at KiCad’s files in a text editor? S-Expressions are human readable, and have a very simple structure.
With an external script, you can also easily do other things. For example, there are utilities that can create PNG images of different projects, and then XOR them to show the differences. Such utilities are mostly made for comparing different versions of the same project. You can also do things such as launch two KiCad instances with different project to examine them further.
KiCad also has a command line interface (called kicad-cli)
I guess that UUID’s do not change when things are moved or rearranged on a schematic, but any copy or paste action will generate new UUID’s. (Even the “Paste Special”, which only preserves RefDes). Making some very simple dummy projects (for example with a shorted resistor) and doing some comparisons will give you more insight in the details. Things like this are not part of the KiCad user documentation, as users are not supposed to interact with the UUID’s (called “timestamp” in historic KiCad versions, “timestamp” is still used to reference to UUID’s in some parts of the software).
Get the suspect students to stand up and then leave the classroom,wait 3 or 4 minutes and then return with the students Mothers. So now ask the students to tell their Mothers that the work they have submitted was their own. Job done
I agree with Paul, it would be easier to write an external program. For a *nix guru this would be very easy: write a regular expression for finding all UUIDs, match and print them line by line, sort, save to file, compare with the other file. Identical file means all identical UUIDs, a copy of the older project where no items have been added or removed.
However, there really is a caveat: items may be deleted and added even if you don’t edit like that on purpose. For example, if you drag an item (wire or track) slightly, it may create new segments and/or delete an old one. Therefore blindly comparing all IDs isn’t good (because you said the students modify the projects). Probably you should compare only symbols and/or footprints.
Then, notice that what you actually need to compare is “path”, not “uuid”. When you add a symbol to a schematic it gets a unique path. This path is added to the corresponding footprint when the PCB is updated.
Do the projects have PCBs and can you assume the PCB file has been created and updated in the standard KiCad way? If yes, you have to use only the PCB files because they include the same paths than the schematic symbols. If not, you can use only the schematic files. Or you can use the schematic in any case – most probably the PCB is irrelevant because it follows the schematic, whether the project is copied or not. It should be enough to find every “path” line and compare them. Then the student must at least delete and re-add a symbol to fool your algorithm. If you want to be strict, you can think about how to compare for certain percentage of correspondence.
Even this doesn’t help if the student opens the original in KiCad, selects what’s there and pastes it to a new project. But this already requires some work and knowing how and why to do it. If it’s a one page schematic and no PCB it would be easy for the student who knows about your automated system. Which means, even if one of them ever reads or hears about this forum discussion…
I wonder if it’s a good Idea to unlist this topic after @hanakp has reached his conclusions. I guess it’s a good compromise to helping a teacher, and not giving (too many) students ideas on how to thwart plagiarism detection.
@eelik Thanks for the tips. I tried extracting component UUIDs in the meantime, and it doesn’t even need any programming. I feed SCH files to (Windows) Grep, search them for “(symbol” string and take next 10 lines. I pipe them to another Grep which returns bare UUIDs. I feed them all to a text file, and use Sort and/or Notepad++ to detect whether there are any duplicate lines. It’s ugly and I have to check the results manually, but I need to do this only once a year. Nevertheless, I’ll probably add some simple improvements, like separating blocks of UUIDs with source file paths etc.
I actually looked inside the files before I even asked here and I indeed wondered about the “paths” in PCB. The students have to do both SCH and PCB and they have to be properly synced etc., I check all that personally in front of them. So next year I’ll probably ditch SCH analysis altogether and just extract paths from PCBs instead.
@paulvdh Yeah, I was reluctant to even ask about it here in the first place. Do you have the rights to hide or delete threads?
Before KiCad, I’d been teaching Eagle and I developed 2 other methods do detect plagiates. But they’re less reliable with KiCad. On the other hand, maybe other teachers could find my script useful, even if it’s currently just 6 lines in Windows CMD file.
BTW, out of 61 projects, I detected 2 plagiates with my old methods and 1 more via UUIDs…
Any moderator, and all level 4 users have the ability to unlist topics. Unlisted topics do not show up in the index, and do not show up in searches. This is mostly used to fight spam.
I am not a moderator, I also don’t want to be a moderator, as my social skills are a bit “below average”, but as a regular I’ve reached level 4 and I have unlisted a bunch of spam topics from this forum myself.
It’s (very likely) not a total delete. All posts and edits are logged in a sourcecode revision system (probably GIT) and I have no control over that. It’s a system which can be used to for example repair deliberate damage to posts.
Why not make them turn in their Git repos? It’ll be a lot harder to hide repurposing someone else’s design than the circumvention to this plan, which is sed -i '/uuid /d' *.kicad_{pcb,sch} (delete all UUIDs and let KiCad generate shiny new random ones on next load).
Plus forcing them to learn version control if they don’t already know it is a hugely useful skill in itself.
I would still say that using “path” would be better than using “uuid”. It would be of course possible to write a script which replaces each “path” in both the schematic and the PCB, so it’s not foolproof either. But nothing is.
Using git is an interesting idea. Git is designed to ensure integrity. It would be difficult to forge the history. Even the hash of the first commit is unique for each new repository made from scratch.
BTW, the OP said
Is the goal to teach to use KiCad, or is it just a tool to design circuits/boards? If the goal is to learn KiCad, any check which prevents copying without knowing how to do it in KiCad helps at least a bit. If the goal is to learn circuit design, nothing prevents looking at an existing schematic/PCB and creating the same with KiCad, and uuid/path/git history doesn’t matter.
Whatever you do, nothing is foolproof. For example, I can ask ChatGPT: “Can I copy git history using diffs and create a new repository based on those with similar commits but different commit hashes?”
It gives at least something to work on. It’s enough that one student is a semi-malicious hacker and writes a script which is applied to the original to create an undetected copy.
In short, if there exist steps to copy and modify a project, which steps can be applied manually without using KiCad, they can be combined in a script which anyone can use. Therefore the check should use some kind of fuzzy logic. It should force the students to take some steps which necessarily vary from one case to another. But I don’t know it that’s possible. For example, for a hacker student it would be possible to modify a final version of an existing KiCad project, then to create a counterfeit git history by creating random chunks of diffs to create commits. At least the examiner should peek into the commit message history to see if it’s sensible. A commit history with sensible messages should then be part of the project requirement. This, combined with automated checks for KiCad files and git repository details might be pretty efficient.
@johnbeard Heh, this is exactly what I was afraid of: that somebody would come along and spill some one-click trick to work around UUID detection. Now I’m really thinking about hiding this thread…
@eelik The goal is both. You can see course annotation here, KiCad section is near bottom. Most students will never use it (or any other PCB EDA) again, but about 1/5 need it for their bachelor’s/master’s thesis. Unlike most manuals, YouTube videos etc., I don’t just teach them “how to click in KiCad”. I intersperse it with real-world considerations like applicable standards, part naming conventions, grounding layout, PCB manufacturability etc. I also spend lots of time demonstating various bugs, pitfalls and general clunkiness, which are unfortunately plentiful in KiCad. (Breaking board sync after cutting and pasting in schematic is one of them.)
Anyway, as a rule of thumb, students who would be smart enough to create elaborate fakes generally don’t tend to cheat in the first place. Using GIT would be another huge headache on top of KiCad, since KiCad itself is already rather user-hostile, particularly to beginners (which about half the students are). But, desktop Eagle will die in 2026 and I refuse to use (and teach) some cloud-based garbage like Autodesk Fusion or Altium 365. It’s one of the reasons why I’ve already replaced most commecial software with open source variants, and KiCad was just another in line.
@johnbeard Maybe edit your comment? No need to give lazy students nefarious idea’s.
I don’t really agree with this. I started with KiCad over 10 years ago, and during evaluation I made my first PCB in KiCad in the first afternoon I Installed KiCad. Back then KiCad had a lot more “missing features”, faults and gaps in it’s capabilities. And the “Getting started in KiCad” was enough back then (KiCad V3 or so, even version numbers were a bit vague back then) to get an idea of the workflow in KiCad and avoid the biggest pitfalls. Also see this other thread: [feedback] My first PCB. Felt pretty easy... what am i missing? - #11 by Piotr A beginner, first project, (probably) did not read much of the manual, was apprehensive to start, but still quite liked his KiCad experience.
For your course:
I understand Git is a bit of a sidetrack. But IMHO KiCad should just be a vehicle, and not the main part of the course. Things like signal integrity and EMC considerations. How to get routing done on a 2 layer PCB while keeping it compact is a puzzle on it’s own, but these days 4 layer PCB’s are getting pretty common. Prices are reasonable, (especially in bigger production runs, the cost difference is manageable). 4-layers also make it much easier to be on the safe side of EMC regulations, and it saves a lot of design time. Two factors that can drive up costs significantly.
Rick Hartley (from altium) has made a 2hour and 10 minute video about the importance and use of GND planes. It’s a very good video with a lot of background info. I think I saw it two, maybe 3 times myself.
No question about that, KiCad v8/9 is light-years ahead of what v4 used to be. It already surpasses some commercial packages (coughOrcadcoughPADS) when it comes to user interface and general usability. But the fact is, Eagle “just works”. You can concentrate on actual design, with no worries about proper symbol/footprint matching, net name conflicts, never-ending manual syncing and other headaches. Sure, Eagle is dated and has its own quirks too, but for total beginners, there was no better option. Its name is acroym for Easily Applicable Graphical Layout Editor and it actually did live up to it. Every year, me and my colleagues used to sat down and mull about other PCB EDAs. But at the end of the day, Eagle had alway won because it’s clean, simple and easy to use. That’s why it became so popular among european hobby community back in early 2000s. But, desktop Eagle is going to die in 2026. In fact, it’s already been dead for the last 4 years. And KiCad is the best (desktop) alternative there is.
During the course, I actually force the students to do a single-layer layer board first, so they would understand the importance of proper component arrangement. Because that’s the most important part of PCB layout, especially on SMD boards. Only then I move to 2 and more layers. Unfortunately, even official KiCad tutorials are as bad as the project you’ve linked - trivial boards that unnecessarily use 2 or more copper layers and super-thin traces. Cringey stuff, even if 2-layer PCBs cost next to nothing these days. Sadly, prevalence of similar “examples” online makes it harder to explain that such ineffective board design has other disadvatages, too. Oh well.
Anyway, the course already devotes 2 hours to grounding and another 2 hours to EMI/RFI prevention. And there is a different course about EMC testing. But as you can imagine, it’s not very popular…
Students generally aren’t smart enough to hide their plagiarism very well. Those who are smart enough are also smart enough to do their own work.
A couple of years ago I did some random searches for some keywords I used in my blog. I discovered a graduate student at a large US university had lifted two long paragraphs from one of my blog entries and inserted them into his project report verbatim as if they were his own work. I wrote to his college, saying that while I was tickled that someone had found my musings helpful, I expected these paragraphs to be formatted as a citation with proper attribution. I also pointed out that this sort of thing could have been a career-ending event, had it been a significant published paper rather than a rather mundane project. I received a very apologetic reply from his supervising professor, and a later check showed that the report had indeed been corrected with a proper citation.
I only wish I’d been in the room when the professor met with his student.
Good to read
These days, there is no price difference at all for single or dual layer PCB’s in the “pooling services”. Single layer PCB’s still exist, but it’s mostly mass produced FR2 such as SMPS power supplies, and cheap consumer stuff. I understand encouraging the students to learn routing on a single layer, but in these modern times, it makes more sense to me to have one continuous GND plane on the back layer, and do all footprint placement and the routing on the front.
When I was evaluating a new PCB program, I tried eagle too, and I found it horrible. I was used to older programs having separate symbols and footprints, and I could not get the hang of how the concept of “parts” worked in eagle. My motivation for learning eagle was also quite low, because it was not an open source project. My guess of it’s popularity back then was that it was “free” and “usable”. That’s a good enough combination for a lot of hobbyists, but I was also already frowning my brows about the board size and layer limits. So I never looked back after evaluating KiCad a week later.
Eagle libraries are one of the main reasons why it’s so easy for total beginners. You don’t have to deal with (extremely error-prone) footprint assignment every single time, because someone else already did that for you. And there is another huge advantage: imagine you have a MCU with 200+ pins that comes in TQFP and BGA package. In KiCad, you have to create 2 symbols with totally different pin numbering. In Eagle, you draw the symbol only once and then create different pin-pad mapping for each package (they call it “Device”). You can also map multiple pads to one pin. AFAIK Eagle and Diptrace are the only EDAs that handle this mapping in sane and efficient manner, all others need to resort to various clunky and error-prone workarounds. Unlike KiCad, Eagle won’t even allow you to switch to a footprint that would result in wrong pin-pad mapping. That’s a big plus for beginners. Sadly, Eagle libraries are getting quite dated now, even though Autodesk made deals to include libraries from Beaglebone and other popular projects.
Granted, most EDAs tout the “footprint assignment freedom and library reusability” mantra. But in reality, if you did the assignment blindly, vast majority of them would be wrong. Even I get it wrong sometimes. As for the reusability, KiCad libraries already contain hundreds of identical footprints just with different names, so that footprint filters can work. Because as it turns out, the “total assignment freedom” is simply too cumbersome to work with. I still vividly remember the nightmare from earlier Orcad and KiCad releases, when a list with thousands of footprints popped at me and I had to manually choose the right one. Thankfully, KiCad librarians spent an eternity to make the footprint filters work, so we don’t have to deal with that.
When I was evaluating my new to be EDA suite (during switch from Windoze to Linux), one of the mayor things for me is how easy it is to create new symbols and footprints, because there are always parts that are not yet in libraries. For me, an extra layer of indirection is just needles complexity and annoying. eagle is not “better” (or worse") in this regard. It’s just different. Different people think in different ways. But to be fair to eagle, I never got far enough to figure out exactly how that indirection layer works. The way KiCad works is much closer to what I expect and appreciate. If I had spend more time with eagle, I may have gotten used to the way it works. And that is also an important issue. When you get to know software better, you learn to appreciate it’s strengths, and live with it’s (perceived) weaknesses and workarounds. After a few years you can even get to the point that you forgot what the workarounds are. You’re just grown used to how it works. That is also one of the reasons that it’s difficult for people who have used a software package for a long time to write a “getting started” manual. Such manuals are (probably) best written by people who started recently and struggled though the quirks and discovered the workarounds so it’s all fresh in their memory.
