I have a project where all footprints are from a project-specific library. A large number of the footprints in the PCB have been modified vs the library. I would like to fix this, so that the library has the exact footprint used on the PCB.
I cannot locate a way to report all footprints that differ.
- The
Inspect > Compare Footprint with Librarytool only works for a single component at a time. - The
Tools > Update Footprints from Librarytool will run for the whole PCB, but does not indicate what the differences are / were (and its effects have to be undone). - The
File > Export > Footprints to New Library...tool will run for the whole PCB, but it assumes that every instance with the same footprint name is identical. It clobbers any # of instances of the same footprint that have been modified differently - in such a situation, I think it ought to create # footprints. Using this tool will also not indicate what differences vs the original library existed.
Have I missed a setting or a solution? Is there a plugin that could help? Is a solution scriptable?
I am using KiCad v9.0.0.
