Comments in schematic
As promised i am splitting
7)Comments like Altium. In Altium you can create a comment sheet (even with graphic). This is usefull to store considerations, layout hints, and etc
in the previous link i get a suggestion to use a “new sheet” to do this. The problem is that every on this sheet will be procesed by DRC, the components drawn in comments will be annotated, and does not allow repeat number.
For example if you do a passband filter with 3 different values (to be assembled for differents frequency under customer requirement) and you want copy a block of schema 3 times with the values for each combination.
