The simplest way I have found of getting python scripts to play nicely on macOS is to put the Kicad python executable path in the shebang line ;
#!/Applications/Kicad/kicad.app/Contents/Applications/pcbnew.app/Contents/MacOS/Python
and then do a sys.import.
import sys
sys.path.insert(0, "/Applications/Kicad/kicad.app/Contents/Frameworks/python/site-packages/")
import pcbnew
from pcbnew import *
Make the script executable (chmod a+x scriptname.py) and then it can be run in place (./scriptname.py).
Here is a script that will plot Gerbers - save it somewhere and call it whatever you want, make it executable (chmod a+x), pass it the *.kicad_pcb name and the desired output directory. e.g.
./plotgerber.py ~/path/to/board.kicad_pcb ~/Desktop/MYGERBERS
Here is the script - I can’t take any credit for writing it - it was cribbed and adapted from elsewhere.
Kicad plot pcb file.
Plot Gerber files in plot directory
import sys
import pcbnew
# Load board and initialize plot controller
boardName = sys.argv[1]
filePath = sys.argv[2]
board = LoadBoard(boardName)
pctl = pcbnew.PLOT_CONTROLLER(board)
popt = pctl.GetPlotOptions()
plotDir = filePath
popt.SetOutputDirectory(plotDir)
popt.SetPlotFrameRef(False)
popt.SetLineWidth(pcbnew.FromMM(0.15))
popt.SetAutoScale(False)
popt.SetScale(1)
popt.SetMirror(False)
popt.SetUseGerberAttributes(True)
popt.SetExcludeEdgeLayer(False)
popt.SetUseAuxOrigin(False)
pctl.SetColorMode(True)
layers = [
("F_Cu", pcbnew.F_Cu, "Top layer"),
("B_Cu", pcbnew.B_Cu, "Bottom layer"),
("B_Paste", pcbnew.B_Paste, "Paste bottom"),
("F_Paste", pcbnew.F_Paste, "Paste top"),
("F_SilkS", pcbnew.F_SilkS, "Silk top"),
("B_SilkS", pcbnew.B_SilkS, "Silk top"),
("B_Mask", pcbnew.B_Mask, "Mask bottom"),
("F_Mask", pcbnew.F_Mask, "Mask top"),
("Edge_Cuts", pcbnew.Edge_Cuts, "Edges"),
("Margin", pcbnew.Margin, "Margin"),
("In1_Cu", pcbnew.In1_Cu, "Inner1"),
("In2_Cu", pcbnew.In2_Cu, "Inner2"),
("Dwgs_User", pcbnew.Dwgs_User, "Dwgs_User"),
("Cmts_User", pcbnew.Cmts_User, "Comments_User"),
("Eco1_User", pcbnew.Eco1_User, "ECO1"),
("Eco2_User", pcbnew.Eco2_User, "ECO2"),
("B_Fab", pcbnew.B_Fab, "Fab bottom"),
("F_Fab", pcbnew.F_Fab, "Fab top"),
("B_Adhes", pcbnew.B_Adhes, "Adhesive bottom"),
("F_Adhes", pcbnew.F_Adhes, "Adhesive top"),
("B_CrtYd", pcbnew.B_CrtYd, "Courtyard bottom"),
("F_CrtYd", pcbnew.F_CrtYd, "Courtyard top"),
for layer_info in layers:
pctl.SetLayer(layer_info[1])
pctl.OpenPlotfile(layer_info[0], pcbnew.PLOT_FORMAT_GERBER, layer_info[2])
pctl.PlotLayer()
pctl.ClosePlot()
