Some time ago, I remember seeing PCB footprints that combined a SMD pad with a conventional THT pad with a hole. Are these available in the current KiCad libraries? If not, where would i find them? Maybe there are some legacy libraries stored somewhere? Thanks.
This is the only reference to these types of footprints that I can find
To answer my own question I’ve found this library
Imagine you have:
• A THT (Pad or Device)
• A SMD (Pad or Device)
And Want to combine the THT and SMD
• Option #1: Just one on top of the other then, ignore DRC error of Silk and Mask etc
• Option #2: Make a Footprint containing both and draw a graphic (for Keepout, Silk… if desired). No DRC errors.
Screenshot shows the two items, then stacked on top of one-another then, a Footprint
(and are set to the same Net (tofu))
