Colours in schematics
As an autoelectrican I use KiCad to make schematics for modifications I do to vehicles. Although KiCad is not intended for this use, it works fairly well. As vehicles contain more and more electronics, KiCad is mor suitable as time gos on.
Often I would like to highlight some lines in the schematics. 0 volt and Vcc are god examples on lines that would be nice to identify by using different colours.
Is ther any way I can change from the standard green to other colours?
You can’t change colors of specific nets. At least not permanently, there is a highlight net tool in 5.0 but it only highlights one net at a time, temporarily.
What you can do is place lots of GND and VCC flags labels on those nets so that there is no confusion what those are.
I have used this technique in the past;
35
And as @SembazuruCDE suggested, matching these to coloured Keystone test points would help to clarify the layout when testing the board.
04
There is a new feature in v5 that could be interesting. One can select colors for graphical lines. (from the full color spectrum)
One can also set the line width and line style.
So, one could approximate a square with a short, fat line segment. Nifty.
Will look more like an oval as the line ends are always rounded.
If you use KiCad as only graphic editor I would replace some wires with graphic lines of selected colour. If you need wires be wires (you use Electrical Rule Checker) I would draw graphic lines in pararell to selected wires.
