When I’m rendering a set of PCBs that each have different colors, it always takes a very long time to go back through each layer and hand pick the color again. Especially when some are HASL and some are ENIG. Also, if I go back to a color I have to try to remember the value if it’s not a default selectable color already available.
It’s also a pain when it takes a while to render a bigger board to go through each layer and sit for a minute between each color change (especially bad if I eyeballed the color wrong).
It would be wonderful to have the ability to save out the current color scheme as a profile and then be able to return to exactly that later when necessary. This would be similar to ZofZPCB, which is the only other way I can find to reliably render my PCBs (but which now doesn’t work due to a new way I’m using to define my edge cuts and also requires me to boot windows).
Thanks for your consideration!
