I have a suggestion regarding the possible errors that can be checked in ERC for the connection of an MCU/CPU with an oscillator or crystal oscillator.
Step 1: Configure the Electrical Type of the MCU/CPU’s CLK pin in the symbol library as an “Oscillator Pin CLK / CLK Pin Output,” and similarly, configure the electrical type of the oscillator or crystal oscillator pin to be connected to the MCU/CPU as “CLK Pin Input / CLK Pin Output.” If configured as CLK, a frequency range for that pin can be entered. A symbol can be created this way.
Step 2: In the schematic, the MCU/CPU is connected to the crystal component at these pins.
Step 3: With ERC, it can be tested whether the MCU/CPU CLK pins are properly connected to the crystal pins as CLK.
Now, you might ask, “What makes this different from other ERC rules?” Well, it allows checking whether the correct frequency crystal is connected between the MCU/CPU. For example, if an MCU is configured to be connected with a crystal between 16 MHz and 25 MHz, it can help prevent errors if a crystal outside this frequency range is connected.
If you ask how important this is, you can find someone as careless as me, who once connected a 32.768 KHz RTC crystal instead of a 32 MHz crystal. ![]()
