CLion & MSYS2 - missing wxWidgets_LIBRARIES
Hi There,
I have been successfully building KiCad from source under Linux and wanted to now build KiCad under windows using MSYS2 & CLion. I followed this guide here: https://dev-docs.kicad.org/en/build/windows-msys2/
When compiling using the MSYS2 console everything compiles just fine. However, as soon as I try to use CLion, CMAKE throws errors. I attached the console output.
C:\msys64\mingw64\bin\cmake.exe -DCMAKE_BUILD_TYPE=Debug -G β€œMinGW Makefiles” -DCMAKE_PREFIX_PATH=/mingw64 -DCMAKE_INSTALL_PREFIX=/mingw64 -DDEFAULT_INSTALL_PATH=/mingw64 …/…/ C:\msys64\home\andre\kicad-source
– The C compiler identification is GNU 10.2.0
– The CXX compiler identification is GNU 10.2.0
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Check for working C compiler: C:/msys64/mingw64/bin/gcc.exe - skipped
– Detecting C compile features
– Detecting C compile features - done
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Check for working CXX compiler: C:/msys64/mingw64/bin/g++.exe - skipped
– Detecting CXX compile features
– Detecting CXX compile features - done
– KiCad install dir:
– Looking for strtok_r
– Looking for strtok_r - found
– Looking for malloc
– Looking for malloc - found
– Looking for math.h
– Looking for math.h - found
– Looking for C++ include cmath
– Looking for C++ include cmath - found
– Looking for asinh
– Looking for asinh - found
– Looking for acosh
– Looking for acosh - found
– Looking for atanh
– Looking for atanh - found
– Performing Test HAVE_CMATH_ISINF
– Performing Test HAVE_CMATH_ISINF - Success
– Looking for clock_gettime in rt
– Looking for clock_gettime in rt - not found
– Looking for gettimeofday
– Looking for gettimeofday - found
– Looking for getc_unlocked
– Looking for getc_unlocked - not found
– Performing Test COMPILER_SUPPORTS_WSUGGEST_OVERRIDE
– Performing Test COMPILER_SUPPORTS_WSUGGEST_OVERRIDE - Success
– Enabling warning -Wsuggest-override
– Performing Test COMPILER_SUPPORTS_WINCONSISTENT_MISSING_OVERRIDE
– Performing Test COMPILER_SUPPORTS_WINCONSISTENT_MISSING_OVERRIDE - Failed
– Performing Test COMPILER_SUPPORTS_WDUPLICATED_BRANCHES
– Performing Test COMPILER_SUPPORTS_WDUPLICATED_BRANCHES - Success
– Enabling warning -Wduplicated-branches
– Performing Test COMPILER_SUPPORTS_WDUPLICATED_COND
– Performing Test COMPILER_SUPPORTS_WDUPLICATED_COND - Success
– Enabling warning -Wduplicated-cond
– Performing Test COMPILER_SUPPORTS_WVLA
– Performing Test COMPILER_SUPPORTS_WVLA - Success
– Enabling error for -Wvla
– Performing Test COMPILER_SUPPORTS_WIMPLICIT_FALLTHROUGH
– Performing Test COMPILER_SUPPORTS_WIMPLICIT_FALLTHROUGH - Success
– Enabling warning -Wimplicit-fallthrough
– Performing Test COMPILER_SUPPORTS_WRETURN_TYPE
– Performing Test COMPILER_SUPPORTS_WRETURN_TYPE - Success
– Enabling error for -Wreturn-type
– Performing Test COMPILER_SUPPORTS_WSHADOW
– Performing Test COMPILER_SUPPORTS_WSHADOW - Success
– Enabling warning -Wshadow
– Performing Test COMPILER_SUPPORTS_WSIGN
– Performing Test COMPILER_SUPPORTS_WSIGN - Success
– Enabling warning -Wsign-compare
– Performing Test COMPILER_SUPPORTS_WMISSING_INIT
– Performing Test COMPILER_SUPPORTS_WMISSING_INIT - Success
– Enabling warning -Wmissing-field-initializers
– Performing Test COMPILER_SUPPORTS_WEMPTY_BODY
– Performing Test COMPILER_SUPPORTS_WEMPTY_BODY - Success
– Enabling warning -Wempty-body
– Performing Test COMPILER_SUPPORTS_WREORDER
– Performing Test COMPILER_SUPPORTS_WREORDER - Success
– Enabling warning -Wreorder
– Performing Test COMPILER_SUPPORTS_WMISMATCHED_TAGS
– Performing Test COMPILER_SUPPORTS_WMISMATCHED_TAGS - Success
– Enabling warning -Wmismatched-tags
– Performing Test COMPILER_SUPPORTS_WIMPLICIT_FLOAT_CONVERSION
– Performing Test COMPILER_SUPPORTS_WIMPLICIT_FLOAT_CONVERSION - Failed
– Performing Test COMPILER_SUPPORTS_WPSABI
– Performing Test COMPILER_SUPPORTS_WPSABI - Success
– Disabling warning -Wpsabi
– Found OpenGL: opengl32
– Found GLEW: C:/msys64/mingw64/include
– Check for installed GLEW – found
– Found GLM: C:/msys64/mingw64/include (found suitable version β€œ0.9.9.8”, minimum required is β€œ0.9.8”)
– Found ZLIB: C:/msys64/mingw64/lib/libz.dll.a (found version β€œ1.2.11”)
– Check for installed ZLIB – found
– Found CURL: C:/msys64/mingw64/lib/libcurl.dll.a (found version β€œ7.75.0”)
– Found PkgConfig: C:/msys64/mingw64/bin/pkg-config.exe (found version β€œ1.7.3”)
– Checking for module β€˜cairo’
– Found cairo, version 1.17.4
– Found Cairo: C:/msys64/mingw64/lib/libcairo.dll.a (found suitable version β€œ1.17.4”, minimum required is β€œ1.12”)
– Checking for module β€˜pixman-1’
– Found pixman-1, version 0.40.0
– Found Pixman: C:/msys64/mingw64/lib/libpixman-1.dll.a (found suitable version β€œ0.40.0”, minimum required is β€œ0.30”)
– Found Boost: C:/msys64/mingw64/include (found suitable version β€œ1.75.0”, minimum required is β€œ1.59.0”)
– Checking for module β€˜ngspice’
– Found ngspice, version 34
– Found ngspice: C:/msys64/mingw64/include
– Found SWIG: C:/msys64/mingw64/bin/swig.exe (found suitable version β€œ4.0.2”, minimum required is β€œ3.0”)
– Found PythonInterp: C:/msys64/mingw64/bin/python2.exe (found suitable version β€œ2.7.18”, minimum required is β€œ2.6”)
– Check for installed Python Interpreter – found
– Python module install path: lib/python2.7/site-packages
– Found PythonLibs: C:/msys64/mingw64/lib/libpython2.7.dll.a (found suitable version β€œ2.7.18”, minimum required is β€œ2.6”)
C:\msys64\mingw64\lib\python2.7\site-packages\wx-3.0-msw/wx/_core.py:16633: UserWarning: wxPython/wxWidgets release number mismatch
warnings.warn(β€œwxPython/wxWidgets release number mismatch”)
– Found wxPython 3.0.2.0/msw (wxWidgets 3.0.2.0)
CMake Error at C:/msys64/mingw64/share/cmake-3.20/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
Could NOT find wxWidgets (missing: wxWidgets_LIBRARIES
wxWidgets_INCLUDE_DIRS) (Required is at least version β€œ3.0.2.0”)
Call Stack (most recent call first):
C:/msys64/mingw64/share/cmake-3.20/Modules/FindPackageHandleStandardArgs.cmake:594 (_FPHSA_FAILURE_MESSAGE)
CMakeModules/FindwxWidgets.cmake:1019 (find_package_handle_standard_args)
CMakeLists.txt:920 (find_package)
– Configuring incomplete, errors occurred!
See also β€œC:/msys64/home/andre/kicad-source/CMakeFiles/CMakeOutput.log”.
See also β€œC:/msys64/home/andre/kicad-source/CMakeFiles/CMakeError.log”.
[Finished]
Add following defines on command line
-DMSYS=TRUE -DMINGW=TRUE -DCYGWIN=TRUE
I added those to my CMake options but still the same problem.
C:\msys64\mingw64\bin\cmake.exe -DCMAKE_BUILD_TYPE=Debug -G β€œMinGW Makefiles” -DCMAKE_PREFIX_PATH=/mingw64 -DCMAKE_INSTALL_PREFIX=/mingw64 -DDEFAULT_INSTALL_PATH=/mingw64 -DMSYS=TRUE -DMINGW=TRUE -DCYGWIN=TRUE C:\msys64\home\andre\kicad-source
Did you clear cmake cache?
Yes, I did that. I am not too sure why CLion causes so much trouble.
Issue is not CLion, it’s that msys shell is different environment.
I noticed you have paths like /mingw64 which are not understood by clion or any shell outside of msys, that may be the problem
Here is my vscode settings for when I used msys build. I had msys installed in d:/devtools so change accordingly
    "cmake.configureSettings": {
        "MSYS": "TRUE",
        "MINGW": "TRUE",
        "CYGWIN": "TRUE",
        "Boost_NO_BOOST_CMAKE": "ON",
    "cmake.configureEnvironment": {
        "PATH": "D:/devtools/msys64/usr/bin;D:/devtools/msys64/mingw64/bin;D:/devtools/msys64/mingw64/x86_64-w64-mingw32/bin;%PATH%",
    "cmake.buildEnvironment": {
        "PATH": "C:/Windows/system32;D:/devtools/msys64/usr/bin;D:/devtools/msys64/mingw64/bin;D:/devtools/msys64/mingw64/x86_64-w64-mingw32/bin;%PATH%",
    "cmake.configureArgs": [
        "-DCMAKE_PREFIX_PATH=D:/devtools/msys64/mingw64/;D:/devtools/msys64/mingw64/x86_64-w64-mingw32/",
        "-GNinja"
    "cmake.generator": "Ninja",
Thanks for that, I’ll give it a go and see how I go.
That’s solved it for me! Thanks mate!
BTW, the msvc build will be the official build for 6.0. You may want to try that instead of msys.
That’s alright. At the moment I just wanted to test a warehouse plugin I am currently building to assign parameters to a part or multiple parts from an external source.
FYI here’s what worked for me
I had to extend CMAKE_PREFIX_PATH and add more MinGW folders to the environment PATH.
