fmp
February 17, 2021, 1:07pm
1
Hello
I’m designing a plate with an LQFP and when I want to draw the different lines I can’t let myself draw due to clearance (I think) how can I change these parameters
I show image of the pads with the clearance line, how can I decrease this glob
I’m using kicad 5.99
Naib
February 17, 2021, 1:39pm
2
file -> Board Setup -> Design Rules -> Net Classes
the default netclass has 0.2mm clearance. Set this to a suitable size based upon your fabricators capability and the copper weight you will use
fmp
February 17, 2021, 3:10pm
3
I change the net class and not change on board
Naib
February 17, 2021, 3:18pm
4
what is the exact footprint you are using?
LQFP-144_20x20mm_P0.5mm ?
fmp
February 17, 2021, 3:36pm
5
No.
I use the footprint LQFP-128_14x14mm_P0.4mm from Package_QFP library
Naib
February 17, 2021, 4:03pm
6
That is the right screen.
So with an LQFP-128_14x14mm_P0.4mm
Exactly the same as what you see
Updating the clearance and minimum trace to 0.1mm 0.13mm
The change is reflected in the board. Likewise it is trackable
what exactly do you see?
also how fine is your grid?
fmp
February 17, 2021, 5:11pm
7
I use 0.02mm of grid.
thanks for your help
system
Closed
May 18, 2021, 5:11pm
8
