in my settings the clearance is set to 0,2mm, but I get an error that the clearance must be 0.254mm.
What causes the requirement for 0.254mm? Please see the images attached for the settings.
Thanks a lot, Best Regards, Seppel
check the properties of both zones (GND-zone / +3V3-zone).
Or log a bug and upload a zip of the entire project.
The report is saying the clearance came from the netclass (which would also include the board minimum, but both those are set to 0.2). So if it’s really coming from the zone or something, then there’s a bug in how it’s being reported…
thanks a lot, I was not aware of that setting. Issue solved.
Best Regrads, Seppel
