I’m trying to place a via for a via fence in an RF signal, but I’m having trouble positioning it exactly where I want because the cursor can’t reach the edge. Is it possible to create a design rule with added clearance to solve this?
You can either reduce the grid size or enter the coordinates of the via manually to be located exactly at the edge. Afterwars you could use “Create Array” to create the fence. Besides that there is a plugin called “RF-Tools” available in the plugin manager which will do this job for you automatically.
