Clearance constraint between different netClasses
I try to define a clearance constraint between different net classes.
My custom rules is
(rule HV-_PHA
   # clearance between HV- and PHA tracks
   (constraint clearance (min 4.0))
   (condition "A.NetClass == 'HV-' && B.NetClass == 'PHA'"))
I just get the message "Could not compile custom design rules, but I can not find what is wrong with the syntax.
When I browse though the Syntax Help I see a difference in the use of quotation marks.
Maybe you also want to add a wildcard to your netclass names.
Thanks for the reply. I found the syntax check button now. I added the missing dimensions (mm) but still get the ERROR “Missing version statement”. I don’t know what this means.
My rules is now:
(rule “HV-_PHA”
(constraint clearance (min 4.0mm))
(condition “A.NetClass == ‘HV-’ && B.NetClass == ‘PHA’”))
I found out the correct syntax for my statement:
(version 1)
(rule “HV-_PHA”
Thanks to ellik and paulvdh for the helpful hints.
OMG! Thanks for finding out!
Why is this nowhere mentioned in the syntax help, that this “version” is mandatory somehow?!
This is described in the full documentation:
We could look to tweak the syntax help, but it’s not designed to be a comprehensive guide.
