I have designed a footprint like shown below.
I used the “Custom Circular” for the outer Pad and set the “circle” size to zero and added only custom primitives. But then this will result in DRC Errors since the outer pads base circular pad with size zero collides with the inner Pad.
Is there a good solution for that? Can i remove the inner Pad completly?
