Circular arrays cannot select an origin (#17862) · 议题 · KiCad / KiCad Source Code / kicad · GitLab
Mod. edit: Moved to new topic as possible bug reports do not belong in announcements.
Function works exactly as expected. User determines center and radius of array. Origins are not used with this function.
Previous versions of KICAD made it possible to center a circular array by placing a grid origin or drill origin
I didn’t remember that.
It appears that possibility has been removed.
Probably best if you create a “Feature Request” explaining how previous versions worked and asking to re-introduce that function.
Posting “Circular arrays cannot select an origin” on gitlab with no other comments will probably get your issue dismissed.
