Circular Array V5.1 Procedure Help
Hello, I’m attempting to make a round PCB with an Array of 36 resistors fanning out from the centre. Finding a few threads on the topic with some visual explanation did improve my understanding somewhat.
I tried to use the same method and origin as Image 01 by selecting R1, or the Anchor of R1 or the entire 36 Resistors. The results are pictured below.
Image 01 Single part no schematic created
Image%2002
Image 02 Created from Schematic below
Image 03
Image%2004
Image 04
Image 05 R1 selected only copies itself and leaves the others untouched
If R1 orientation was set to -45 the circle would look like Image 01
Image 06 This is when I select all
What a mess, there are still the original 36 components as in Image 04 untouched under here.
@MagneticFlux
No need to flag this for being incomplete. You have the ability to edit it.
Can’t see your problem.
Copy one resistor foot print into you project library. Arange that resistor in different angles as needed.
Away you go.
