Please dont tell me, i have to get out my pencil and note down the center coordinates of a circle that i want to place vias around, when creating an circular array.
I even tried to be smart and started thinking there must be an easier way: Then i had the idea to place the origin there instead of noting down the coords. It did not work. It didnt work with the origin for drill files either!
A google search only brought results with scripting…
Can it be done without scripting? I dont want to write a script nor have more paper on my desk.
You can use: PCB Editor / Place / Drill/Place File Origin (Also in the toolbar on the right side) to define a center point, and then use (0, 0) in the array tool as the center point (relative to that drill origin)
Yes, indeed, that seems to be the cause. For the previous arrays, PCB Editor / Preferences / Preferences / PCB Editor / Origins & Axis / Display Origin was set to Drill/place file origin
I also had a look at the official documentation. It does not mention what the center point of a circular array is. This is a bit confusing, but in retrospect, it’s also quite simple and logic. In the array tool you can set absolute coordinates for the center point, and these absolute coordinates are interpreted in “display coordinates”, and this can be any of the three options listed in the preferences.
Another option is to use the Place Footprint plugin. I have not used it myself so I don’t know what it does exactly, but it claims to be able to create a circular array.
Because KiCad always uses its own internal coordinate system internally, in internal workings and in the file format, and what you see in the UI can be changed. Actual coordinates of items etc. aren’t changed, only how they are displayed. Being able to change the visible coordinate system – origin and direction of axis – has been added to KiCad only “recently” in its history.
we’re probably running into interpretations and definition confusion with the english language WRT the word ‘display’.
A better word, IMO for display would be the canvas. LOL…
For me the ‘display’ is the whole monitor… Not the window area with its own coordination origin.
