Circuit diagram editor, error renaming the value
Just discovered that the symbol’s value field is no longer editable.
Where can I store my KiCad version in the forum?
You want to place/post your Kicad version into this forum?
Yes, I would like that so that everyone knows which version I am working with.
Open Kicad, go to help > about Kicad > top Right corner is “copy version info”. Left mouse click that box then open reply in the forum and right mouse click and “paste”
Yes, I know that. Can’t I put it here in the forum directly under my name?
Yes, right mouse click then select Paste. It should look like my post.
Application: KiCad x64 on x64
Version: 7.0.9-rc1, release build
wxWidgets 3.2.3
FreeType 2.12.1
HarfBuzz 8.2.1
FontConfig 2.14.2
libcurl/8.4.0-DEV Schannel zlib/1.3
Platform: Windows 11 (build 22621), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Oct 26 2023 05:13:50
wxWidgets: 3.2.3 (wchar_t,wx containers)
Boost: 1.83.0
OCC: 7.7.1
Curl: 8.4.0-DEV
ngspice: 41
KICAD_SPICE=ON
The value field of power symbols is not editable. My German is not good, but I guess that is what the cursive text just under the entry field means.
To fix it, load your symbol in the Symbol Editor, and then: File / Symbol Properties and remove the flag in the Define as Power Symbol checkbox.
Hello @paulvdh, after opening KiCad and the symbol editor, I got a message that I have a suspicious voltage symbol. After I marked the symbol as not a voltage symbol, I was able to edit it again accordingly.
But for me this is a step backwards, since I now e.g. E.g. I have to insert 5 individual conductors, or I can’t define the voltage symbol.
But I also don’t understand that the multi-pin terminal block can be easily renamed.
So I changed the symbol again. I connected all three pins and colored them white.
fehler
You can see it nicely when marking.
