is there a way to force a direction of the routing from a starting point? Hard to explain what I mean. Sometimes the routing track goes 45 degrees and then straight and sometimes it goes first straight and then 45 degrees. Is there a way to specifically choose this? It seems quite often I would like to change the direction but it just snaps to one or the other without any way to actively choose it. I would post some images but I can not see how.
Ok I found it now. Its the “Switch track posture” hotkey.
Curiosity as a follow up:
To me it seems that this track posture nearly always starts in the wrong direction.
Do others feel the same?
Would it be worthwhile to make a feature request to make the default configurable?
The posture can be set by how you move the mouse when you start routing. It also has different defaults depending on the pad shape and angle of the starting pad (when starting from a pad)
